Page 1 of 2
Fuel temperature from flex fuel sensor
Posted: Mon Nov 20, 2017 10:57 am
by Slowie
Hi
The ability to read fuel temperature from a flex fuel sensor would be great, and would save an extra input, in cases where fuel temperature is required.
Re: Fuel temperature from flex fuel sensor
Posted: Mon Nov 20, 2017 6:54 pm
If Syvecs/Life Racing can't do this, I could add it to our Mini Expansion Unit easily enough Image
Posted: Mon Nov 20, 2017 7:47 pm
I think all the flex fuel sensors incorporate this already ?
Not sure whether the ecu is normally configured to accept it though ?
Posted: Mon Nov 20, 2017 7:49 pm
stevieturbo wrote:I think all the flex fuel sensors incorporate this already ?
No, the ECUs don't have support for fuel temp. I asked ages ago.
Also, not all flex fuel sensors measure temperature.
Posted: Mon Nov 20, 2017 11:53 pm
by tpepmeie
TimH wrote:No, the ECUs don't have support for fuel temp. I asked ages ago.
The Life F88 has a Fuel Correction Multiplier table for Fuel Temp. I figured the Syvecs line would have the same?
Posted: Tue Nov 21, 2017 7:09 am
Its support for interpreting fuel temperature from the flex sensor that the ecu doesn't have.
Posted: Tue Nov 21, 2017 10:22 am
As Tim says, you can supply fuel temperature from a regular analogue input....just not via the inbuilt output on a digital flex fuel sensor.
Posted: Wed Dec 09, 2020 7:18 pm
by MReilly
I agree on this and reckon it's worth a bump.
Almost seems strange not to have it, even the old DTA ecu can do this.
I wonder, is there a reason perhaps?
Posted: Thu Jan 13, 2022 5:37 am
by amdisthebest
Bumping again for good measure.
Fuel temp is output from a standard GM ethanol content sensor with the following linear scale:
1ms PW = -40c
5ms PW = 125c
Maybe there's a sneaky way we can already use this info, if not, it would be killer for the team to add it.
Posted: Wed Jun 22, 2022 3:14 pm
by amdisthebest
Just bumping here again. I don’t want to make a list but several other competing ECU’s do this natively. Spanning from some fairly inexpensive units all the way up to the most high end systems out there. Hoping we can get an update to allow this :)
