It would be very nice if SMon can work in Full Screen mode without top and left side menus for those running car computers in their cars.
I think this won't be a hard task, is it?
Custom gauges would be nice though but I know you don't have time for this =)
SMon
Re: SMon
By the way, I was able to save my layouts on the older versions but now I see that I can't save it. What is the problem?
I am opening a New Layout / Adding gauges / but the save option isn't there. I tried to Overwrite Layout or save default layout with no go. Weird.
I am sure I have done this before. I saved my gauges and it was automatically loading them when I start the SMon.
Cheers.
Cheers.
Re: SMon
to answer my question..
I think I am doing it verse vice. I'll try this tomorrow.
pat wrote:I would suggest setting it as the default layout...
Setup the layout that you want, then save it using Gauge -> New Layout. It will ask for a name, so give it one. Next you'll be able to do Gauge -> Set Default Layout. After that it will use that layout as the default when it connects to the ECU
